I was working on one of my project templates last week, and after saving and closing it was in Recent Documents later that day when I needed to re-open it. Now it isn't there (I haven't done much since then, it should still be near the top), so I tried to open it through the file explorer and it opened in a separate Revit instance (which also isn't consistent). On that note, the pin for Recent Documents does literally nothing. Has anybody else faced similar issues? I can open the file through Revit, but it's really annoying to dig through the folders when I should be able to pull it up from Recent Documents.
So, I'm guessing that this may be related to the Revit.INI File. That's where I would start troubleshooting from.
Regarding PINNING, read this:
https://help.autodesk.com/view/ACDLT/2023/ENU/?guid=GUID-CB0CCA6C-91EB-4E59-A036-3331D0EDE154
