Project Parameter
5 ANTWORTEN 5
Nachricht 1 von 6
g_veerattan
434 Aufrufe, 5 Antworten
Project Parameter
By Loading Shared Parameter in Revit Its giving option to load Project parameter One by One, As I have too many Parameters in Shared Parameter Single Group It is taking way too long to work on the project. Kindly advise any quick solution to add up all Parameters from a Shared Parameter Group
Beschriftungen (2)
5 ANTWORTEN 5
Nachricht 2 von 6
alan.johnson7YLND
als Antwort auf: g_veerattan
I think you will need a 3rd party add-in.
Check the app store.
Nachricht 3 von 6
g_veerattan
als Antwort auf: alan.johnson7YLND
Thank you alan johnson will check it.
Nachricht 4 von 6
Nachricht 5 von 6
Try DiRoot One parameter manager.
Nachricht 6 von 6
BDMackey
The other thought here is to look into the Parameter Service. This stores parameters online and can be set to have default values and grouping and a selection for loading as many as you want. Probably not what you want currently but a great option for use in the future.
