Project parameter
Project parameter
XXalessio.amodioXX
Message 1 of 9
Project parameter
XXalessio.amodioXX
Hi all,
I wonder if there is a way to add a project parameter to a certain family instead of whole category (e.g. Generic model)
Replies (8)
Message 3 of 9
martijn_pater
I think you're looking to use shared parameters? Mentioned in the link above also, but a bit more the direction you're looking for maybe. Is it for scheduling?
Message 4 of 9
XXalessio.amodioXX
It is for Dynamo coding but in forum They told me not possible
Message 5 of 9
martijn_pater
Still unclear what you're trying to do, perhaps if you elaborate some more. But I suppose if on a Dynamo forum it is said to be impossible, then I guess it most likely is...
Message 6 of 9
hmunsell
the point of a Project Parameter is to apply the parameter to the whole projector based on Category. why not just make a Generic Model with a Shared Parameter in it instead of a Project Parameter, like @martijn_pater suggests
Howard Munsell
Message 7 of 9
XXalessio.amodioXX
Using Shared parameter is an Idea, but for dyanamo coding it was not working.
Nevermind
Message 8 of 9
martijn_pater
I'm not that advanced with Dynamo, but I think you could perhaps use Element.SetParameterByName node to set some shared parameter value(s)...
Message 9 of 9
bin
You can just use Family Parameter for Dynamo.
