I found a question about "Project North" and "True North" shown in the screenshot below:
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Hi @xinghuangYG69F,
I assume you haven't defined a rotation for Project North. Maybe this will help:
Rotate Project North | Revit 2022 | Autodesk Knowledge Network
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
maybe this one helps? thanks
DWGs insert into Revit with True North at 12 o'clock high - unless they are inserted via Shared Coordinates previously established. So, you need to rotate the DWG to orthogonal - just like you rotate anything else.
If it matters, you can Acquire Coordinates of the DWG - if it's Linked. That will set your Angle to True North per the DWG. Then you can toggle your Revit Plan Views between Project North and True North Views.
