Project Browser Views Missing
I recieved a Revit file from an Architect to help with detailing out our scope of work for the project.  When I open the file I can't see any views?  I am able to go to the 3D view and see the project and scope boxes each portion is in but I can not navigate to floor plans, roof plans, sections, elevations, or details?  I've tried to look in the View dialog box and I've tried to filter/search for views?  Is there something I'm missing to show the hidden views or is it possible they have all been deleted prior to uploading them to a share file?  Any help would be greatly appreciated.
chrisplyler
It's possible the Project Browser Organization has been set to the Not on Sheets option.
I tried switching to the all check box under Browser Organization and it still shows limited views. I'm beginning to think they've deleted them to protect the project?
L.Maas
Yes, It is quite possible that they cleaned up the files and deleted all/most views. It might be done to reduce file size. Ot it is the model they use for linking into other files.
It should be possible to create new floor plans ("View", "Plan Views", "Floor Plans").
You also could consider to give them a call and ask.
Louis
Please mention Revit version, especially when uploading Revit files.
