project browser not showing
5 REPLIES 5
552 Views, 5 Replies
Hi.. im using revit 2020. my project browser went missing.
i don't use dual screen. Tried reopening the software several time.
have we got a solution?
Labels (2)
5 REPLIES 5
View Tab=>User Interface=>Project Browser
selmanyesil
see image below
In view tab click User interface
Selman YEŞİL LinkedinYoutube
sureshchotrani
Welcome to the community.
Kindly reset the Revit, https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
That should work.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
in reply to: barthbradley
not working..
sureshchotrani
Are you using dual monitor? If yes, make sure both monitors are set to 100% displace setting.
Forma Design Contest
