Project Browser missing the 3D view
Hey,
im new to revit and im using the 2017 Student version.
i am missing the Project Browser  3D view and i also not managing giving wall top constraints after defining the level heights ...
Please help
loboarch
You have to Create a 3d view (on the view tab of the ribbon) and walls have to have the top constraint set in the properties palette to reach the level you want, or set the top constraint as you add the wall to the model.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
The first one was easy , THANK YOU
The top constraint thou doesn't give me the option in the properties to enter or select the wanted level constraint ...
It is saying 'not connected' and no other options open up ...
any idea?
loboarch
Select a wall and in the properties palette you can set the top constraint to a level datum in you project. It is in a pulldown on the property itself.
Jeff Hanson
Revit Help |
No, it doesnt work..
It doesnt give any option other then unconnected... even thou i have all the levels set on elevation
I tried searching for an answer but in all the web tutorials the software magically works ...
loboarch
Have no idea on why this would not work. Have not ever really come across an issue where it simply is not an option. Try in an empty file and see if you can place a wall with a top constraint. Perhaps there is something wrong with your file?
Jeff Hanson
Revit Help |
