Project Browser Floor Plan order
5 ANTWORTEN 5
Nachricht 1 von 6
SLE_MZ
373 Aufrufe, 5 Antworten
I'm working on organizing floor plans in associate-level order.
The order I set works as I like, but it added a line to the elevation and section.
What is it, and how can I remove it?
5 ANTWORTEN 5
Nachricht 2 von 6
vitorbortoncello
als Antwort auf: SLE_MZ
right click your project browser organization and check the view organization properties:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 6
SLE_MZ
als Antwort auf: vitorbortoncello
Thank You! now the order is correct but I dont know why the question marks
Nachricht 4 von 6
SLE_MZ
I relisted the settings and now its perfect. thank you!
Nachricht 5 von 6
TripleM-Dev.net
The ??? are the Associated Level parameter selected to be included in the grouping.
As the Elevations/Sections don't have a associated level it's shows ???
Using the Associated level only as Sorting (as you're last post) the ???  Won't show but is used for the sorting.
Nachricht 6 von 6
SLE_MZ
als Antwort auf: TripleM-Dev.net
I didnt want the ??? so worked around it. thank you!
