Project Browser Collapse on Closing of Revit
3 ANTWORTEN 3
Nachricht 1 von 4
jwakefieldMM4B2
817 Aufrufe, 3 Antworten
As the title suggests, I am wondering if there is a way to set Revit to automatically collapse the tabs within the project browser once you sync and exit the program?
This may seem trivial at first glance but when the project is shared via a Central Model it could be overwhelming for a new user to open the project and see the sensory overload that is a project browser with EVERY tab revealing their drop downs.
Anyways, if someone knows if this is possible and how to set it up that would be great!
Best,
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: jwakefieldMM4B2
You can Collapse All in one fell swoop.
Nachricht 3 von 4
jwakefieldMM4B2
als Antwort auf: barthbradley
I am aware that you can right click and select collapse all. However, if someone doesn't do that before they sync and close, the next person to open the project will have all the panels open from the project browser left by the previous editor.
I am looking for a way to automate this process so that no matter who saved last or who opens the project the project browser is fully collapsed to only show the Category titles when the project is re-opened.
Nachricht 4 von 4
Maybe through the INI file?  :denkendes_Gesicht:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
...you ought to post on the API forum as well.
