What is the recommended fix, when the Project Browser and Properties Palette freeze in Revit but not the drawing window or it's elements.
Gelöst! Gehe zur Lösung
Gelöst von dzanta. Gehe zur Lösung
this may be a graphics driver issue...verify your card is certified for revit and using the proper driver
do a repair on revit if necessary
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Hi, this has started doing this with myself running Revit 2024 v 24.2.0.63. Project browser completely freezes and cannot select any views or sheets etc. All other tabs, etc work fine. Any update on a solution. Graphics card running latest drivers etc. Never happened before now.
Did you ever get a solution for this? We are experiencing the same issues since moving to Revit 2024
Nope, still have same issue. Project Browser freezes in 2024. I re-installed software twice and still same issue. Need a fix for this as having to restart Revit every time it happens is really disruptive.
