Project Base Point - Level Relation Issue
Message 1 of 11
I have a Project Base Point which has a -120(mm) elevation value. (So it's 120mm below the Survey Point) The first level is physically 120mm above the Project Base Point. But when i select this level and check the properties the elevation value shows 0.00 even though the level is using the Project Base point as referance.
Thanks for any kind of help.
Replies (10)
Message 2 of 11
hmunsell
check the rounding that is set in the family Label.
in this example my PBP is set to -2", but i have the rounding set in my Level Head family set to "0" decimal places.
Howard Munsell
Message 3 of 11
Where did the Level Head Family come from? Looks custom. I'd like to check out the family and the labels.  Can you post it?
My guess is that it has something to do with "Site Level".
Message 4 of 11
Thanks for the reply. I checked the label. It is set to show 0 decimal places. It doesn't explain the 120mm difference. Besides i check with other level head families which works perfectly in other revit files but they didn't work on my file. Most likely it's not family related. 4.JPG
Message 5 of 11
Thanks for the reply. Sure!
Here's the family.
https://we.tl/t-XokDz9wRFg
Message 6 of 11
So you are seeing something like this which you don't understand?
Message 7 of 11
No this looks quite normal. My problem is elevation related. Level elevation seems 0.00 even though it's 12cm above the Project Base Point.
Message 8 of 11
martijn_pater
Strange, that shouldn't be the case... Any linked models? Could you share the file?
Message 9 of 11
I managed to solve it. I think there's a bug on elevation info in Revit. It doesn't show the numbers in real time. I simply unclipped the Project Base Point moved it above the problematic level. Then moved it back to the original location and now the level shows the correct elevation. It's so strange even though i re-opened the file tens of times the level didn't read the current elevation of the Project Base Point.
Thanks all for the help.
Message 10 of 11
martijn_pater
Re-opening the view or zooming usually does the trick, to update the drawing that is...
Message 11 of 11
I would suggest NOT duplicating the built-in "Elevation" Parameter. Instead, create another Label as a Calculated Parameter.
