Completely agree
After some experience using the new workaroung, and been able to compare to what was before, is definitely less eficient than in the past.
A- Before, the same thing was possible with at least two methods. Keeping the PBP with the "pin activated" to change the relative coordinates of the project (the coordinates reported when "survey" is defined in the Spot Elevations or Spot Coordinates)
1-Introducing the N/E/H values directly in the PBP (a very useful tool, very precise and easy to manage)
2-Moving the PBP graphically (that is very similar to what is possible now)
To change the reference to the Project Coordinates (the coordinates reported when "project" is defined in the Spot Elevations or Spot Coordinates) the only diference was to "deactivate the pin" and introduce the N/E/H values in the PBP or to move it graphically.
B-Now, the only way to achive the task of changing the reference of the Relative coordinates of the project is by the "Relocate Project". So, just for this, is a lost in efficiency and precision to the same task. The posibility of typing the values was a very very useful tool that is gone.
And to change the reference of the Project coordinates, the workaround just "increase in eficiency" by avoiding to "deactivate the pin".
So, in conclusion, it was taken away eficiency from one aspect (the change of the reference to relative coordinates) in a hard way to just increase a little the change of the other aspect (the change of the reference to project coordinates)
From my perspective, the confusing about this tool and concepts are still there, it just was modified from one state of confusness to another. For any one who is starting to undertand this thing of the coordinates and references, the confusing will be, just in another way. And for the ones that knew about this, and actually worked with this, it is now real drawback.
There are statistics about how satisfied are the users of Revit about this modification?
Are the "great majority" satisfied with this?
