Project backup file no .rvt file only .rws .dat
6 ANTWORTEN 6
Nachricht 1 von 7
emile_montanet
434 Aufrufe, 6 Antworten
I work on a local file, I have set the number of backup file to 20. Revit did create a backup folder but there isn't any xxxx_001.rvt file in it, only .dat and .rws files as you can see below, how to solve this?
6 ANTWORTEN 6
Nachricht 2 von 7
Alfredo_Medina
als Antwort auf: emile_montanet
The .rvt files with the 00# numbers should be in the same folder where the working file is. You´re looking into the backup folder, which is used for rolling back to a previous version of the model, in case of corruption, using those .rws files.
Nachricht 3 von 7
jay_colcombe
I have seen some issue lately with local models not backing up on onedrive which usually is typical with workshared models.
Is the file location you referenced in the Journals folder as per the reference below?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Where-does-Revit-s....
Jay Colcombe
Autodesk Certified Instructor
Nachricht 4 von 7
emile_montanet
als Antwort auf: Alfredo_Medina
I can not find any other .rvt file in the folder either. Maybe it is because I'm working directly on the central file ?
Nachricht 5 von 7
jay_colcombe
Hi, there is a specific reference in the Link above
How to find the local copies of Revit Cloud Workshared files (autodesk.com)
Jay Colcombe
Nachricht 6 von 7
emile_montanet
als Antwort auf: jay_colcombe
Thank for your help, can't find any folder named "Collaborativecache" as in the link above.
Nachricht 7 von 7
jay_colcombe
Have a look in the original link and try every scenario listed just to make sure we are covering every base.
Jay Colcombe
