Profile-Edited Walls not Joining
5 ANTWORTEN 5
Nachricht 1 von 6
azhoq36UAA3
971 Aufrufe, 5 Antworten
Hi All,
Would appreciate some assistance with this wall joining issue i am having.
As you can see from the image, i have a porch-like area on ground floor level with the first floor covering the porch. I have used edit wall profile to create the indents/opening on the ground floor level. But the corners of the walls on first floor level are not joining - leaving a line and blank patch which clearly shows no join is occuring.
Any help would be much appreciated!
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: azhoq36UAA3
Try and pull the corners apart and them trim them together again.  Revit does not usually like walls with edited profiles so an alternative option is to have different walls above the openings, starting from lintel height.
Nachricht 3 von 6
Worst case, use Join geometry and manually join them.
Nachricht 4 von 6
I can see in your screenshot that the edited profile is stopping short of the join point between the two walls.  Edit profile again and lengthen the end of the wall a bit.
Nachricht 5 von 6
So at the join line....align to the center of the wall of the adjacent wall...so tab until you see the dashed line of the center and align to that.  Should work after that.
Nachricht 6 von 6
azhoq36UAA3
Thank you all for your suggestions. I shall give them a go and let you know how i get on.
Much appreciated!
