Product return & multi-use
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
narell
365 Aufrufe, 3 Antworten
I have just purchased Revit LT 2019 Suite, however am thinking of returning it and getting the full version of revit.  Before I do so though, can I install Revit on both my PC & Laptop so I can use Revit whilst away from the office?
How easy is it to return a product?
3 ANTWORTEN 3
Nachricht 2 von 4
Viveka_CD
als Antwort auf: narell
Hi @narell
I see that you are a new visitor. Welcome to the Autodesk community! Smiley (fröhlich)
You can post your query and contact a licensing support specialist at this link - Purchasing or returning my product
You can also try to post oi the licensing forum for further feedback.
Hope that helps!
Nachricht 3 von 4
Viveka_CD
Hi @narell
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Nachricht 4 von 4
@narell
Not sure about the returning the product, but I think you have 30 days to do so.  If  you are under the 30 days it should be pretty straight forward.
As for installing on both your PC and Laptop....yes, you can install on both.  Because Subscription requires you to login with your Autodesk ID essentially you can login on as many different computers as you want....but only for the amount of licenses you have.  So if you have one, you can only login on one.  Be sure you log off/close Revit on one machine if you jump over to another as it will close if you login on another machine.
