Procedural tile texture in bump material channel
8 ANTWORTEN 8
Nachricht 1 von 9
mskrzypczakM6PHY
833 Aufrufe, 8 Antworten
The procedural map does not applied correctly.
Tags (1)
8 ANTWORTEN 8
Nachricht 2 von 9
pendean
als Antwort auf: mskrzypczakM6PHY
What software are you using? Your screenshot is alien to the topic of this ADR forum.
Nachricht 3 von 9
mskrzypczakM6PHY
als Antwort auf: pendean
Thanks for your response. I couldn't find better place to posted this issue. If you know a place where this topic fits better please let me know. I'm using Revit 2021. Thanks in advance for any help.
Nachricht 4 von 9
pendean
>>>...I couldn't find better place to posted this issue...<<<
Why not in the REVIT forums instead of the ADR free viewer forum that cannot do anything with REVIT files? Here is the link https://forums.autodesk.com/t5/revit-products/ct-p/2003
Nachricht 5 von 9
semhustej
What is the problem? I can see bit of bump on your cube in the screenshot.
Tom
Nachricht 6 von 9
Nachricht 7 von 9
even if it is possible not to appear in the Preview, it will appear in the applied material..
  • the Preview window doesn't show the bump:
  • but you can see it into the Project
Constantin Stroescu
Nachricht 8 von 9
Thank to all of you for your answers. For some reason this map doesn't work in render. You can see it in the viewport in "Realistic" mode, but its behavior is the same as in preview.
Nachricht 9 von 9
greerco
@mskrzypczakM6PHY Have you tried using 'cutouts' instead of 'bump'? I was trying to do something kind of similar but with a concrete material to show the control joints and the cutout with the same tiled pattern worked okay for me... You'll likely need to put another layer of material behind it so that it doesn't actually cut thru.
