Buenas tardes. Al bajar las librerías de revit 2019. Veo que no tengo la familia original de etiqueta de material para cargarla. Alguien podría pasarmela.gracias.
Gelöst! Gehe zur Lösung
Gelöst von lim.wendy. Gehe zur Lösung
Gelöst von mauricio_mssf. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
You can create one yourself by copying and recategorizing a Tag that you do have.
Follow these steps
File >> New >> Family >> (Choose any annotation category, i suggest generic annotation).
Sigue estos pasos
Archivo >> Nuevo >> Familia >> (Elija cualquier categoría de anotación, sugiero una anotación genérica).
Después de eso, simplemente cree con los parámetros que le gustaría.
After that just create with the parameters you would like.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
Hola @pablotrarq.
Thank you for submitting your question in our discussion forums. Have you had a chance to look over the suggestions provided by our experts?
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you? ![]()
