Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Problems with unit conversions in family formulas
dbroad
dbroad
I was trying to debug a cabinet formula that wasn't working this morning
The project units were fractional inches with a precision of 1/128".  Some dimensions were in mm.
The original formula as keyed in
round(Holes/(ShelvesRows+1) * 32mm-8mm
which got converted to
round(Holes / (ShelvesRows + 1) * 1 67/256" - 81/256"
Holes and ShelveRows are integers. The result was supposed to be an accurate distance.
The resulting dimension was 0.5+- mm off.
The corrected formula:
(round(Holes / (ShelvesRows + 1)) * 32 - 8 ) * 1" / 25.4
This did the conversion without using the mm suffix but was dead on.
Using mm suffixes was convenient but imprecise. This post is a notice to help others and doesn't require a solution. In short, avoid using unit suffixes in formulas when accuracy is required.
Architect, Registered NC, VA, SC, & GA.
HVAC-Novice
All good points. In general you want to avoid mixing metric and IP units. A lot of rounding going on that may add problems and may cost resources (not sure on that one).
Revit version: R2025.3
Mike.FORM
Although half a MM is not much of an error, if you are doing lots of calcs with formulas it can add up if units keep switching.
If I am using some static lengths/sizes in a formula I will usually set the units of the family to the units I am using, in this case I would change to MM.
