Problems with topo surface triangulations
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
Per.Eliasson_Mondo
1052 Aufrufe, 8 Antworten
Ripping my head of soon! Revit is by far the worst software ever created with modifying topo surfaceses. Ive created a surface in civil 3d and trying to insert in Revit. Should be easy but it isnt at all.
Getting this problem for example. how the H*LL do I get this line deleted?!?! There is no reason why revit should draw this line at all. Anyone here that is better than me at doing this? I know civil 3d, but this just pisses me of! haha
Beschriftungen (1)
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Per.Eliasson_Mondo
Contour?
On Site&Massing Tab.
Nachricht 3 von 9
als Antwort auf: barthbradley
Nachricht 4 von 9
Did that turn your frown upside-down?
If not, beer works too.
Nachricht 5 von 9
one more for you...
Nachricht 6 von 9
@Per.Eliasson_Mondo
I suspect that the points along the curb are the outermost points of the toposurface.
In a plan view, if the curb curves inward towards the center of the surface, Revit's algorithm will enclose them by connecting the outermost points.
The solution would be to add a point outside the added edge and then split the surface.
-luc
Nachricht 7 von 9
Solved it! I did as you told me about splitting it. But I couldnt make a point outside the surface. Got this message when I tried. Did the thing that revit told me and placed a point inside the surface and moved it..... GOT THE SAME MESSAGE AGAIN hahahahahaha!
But I tried to split the area where the interpolation was and that worked, so thank you! :leicht_lächelndes_Gesicht:
Nachricht 8 von 9
I can feel the warmth of that upside-down frown all the way  from here!!!  Wow! I think we even have lift-off.
Can you confirm lift-off mission control? Over and out.
Nachricht 9 von 9
Look at this Link it will help you and Good Luck
https://www.augi.com/articles/detail/better-site-coordination-and-topography-an-autocad-civil-3d-and...
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
