Problems with shared coordinates
Message 1 of 8
Is it possible that when im linking one file with shared coordinate it comes on correct position even after having different shared coordinates and vice versa?
Replies (7)
Message 2 of 8
ennujozlagam
hello, No. the link file should follow the current coordinates. thanks
Message 3 of 8
But it is happening with me.
Message 4 of 8
ennujozlagam
unless you save the link file to current coordinates. thanks
Message 5 of 8
can you please elaborate as im unable to understand.
Message 6 of 8
cbcarch
Read this:
http://paulaubin.com/_downloads/2015_RTC/Aubin_Revit_Coordinates_2016.pdf
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 7 of 8
Sure it's possible. The Link could have multiple named shared sites defined (Location=>Weather and Site dialog =>Site Tab).  Which one is the Link using inside the Host?
Message 8 of 8
Corsten.Au
Theres a difference between
1. Relinking and
2. Reloading
File linked.. multiple instances, each instance is saved with their corresponding location..
unload and reloading will help get those instances matched with corresponding location..
but if you are going to relink some other file....then probably not..
relinking the same file.. ( called " reloading " ) will work...
let us know if that helps...
Corsten
Building Designer
