Problems with room bounding walls.
5 ANTWORTEN 5
Nachricht 1 von 6
jfjacques
1023 Aufrufe, 5 Antworten
I go to highlight room bounding objects and find that most of my walls do not seem to count as room bounding objects.
I'm wondering why this is: what could make the room bounding algorithm ignore these walls?
These walls go to the appropriate height and I've reset their profiles.
If I delete these walls and redraw them, the new walls seem to become room bounding once again.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: jfjacques
Check the base offset see if they are 0. Are there any rectangular openings?
Nachricht 3 von 6
jfjacques
als Antwort auf: ToanDN
Nope, that's the first thing I checked. No openings and no offsets either at base or top.
Nachricht 4 von 6
H.echeva
This could be the computation height of the level.
Check if your room is hosted in the correct level.
Check computation height of the level.
Check height of the room and base offset.
I hope this helps
Nachricht 5 von 6
jfjacques
als Antwort auf: H.echeva
What is the computation height of the level?
Nachricht 6 von 6
H.echeva
The computation height is a property of the levels that tells revit where do you want to cut the room to calculate the room area.
See this link: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
