Problems with new template
3 REPLIES 3
DhrVandebeek6214
221 Views, 3 Replies
I'm making a template from scratch. But I have a problem defining my level of detail and my graphic display. Can anyone help me and tell me where I can set this up? See the photos below to see which problem it is.
3 REPLIES 3
Your view is probably associated with a View Template, which controls that. You can either remove the View Template by setting it to None or change your settings in the View Template. view-template-revit/
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Thank You. I've set it to none and now it's working.
I'm going to revisit where it went wrong with my view template.
You can exclude Parameters from the View Template:
So in your case: Detail Level and Model Display
