Hi everyone,
I am having trouble with mirroring a family I made.
When I use mirror it mirror not only on the axis I drew or pick but also on another one.
Also when used in a group and I mirror that group all the families in that group twist or get flipped.
Don't exactly know what cause this. But I attached the family and a test project.
I more information is needed please let me know.
Thanks anyways,
Assoicate the "Flipped" and "Mirrored" Parameters to Family Type Instance Parameters in the Family. "Rotation Angle" too if you like.
Thanks @barthbradley,
But there is not a way to make the normal mirror tooling work?
I find it really hard to believe that mirroring over two axis is intended.
Why would you even draw or pick an axis than.
Does anyone know what the reasoning is or what it is with generic adaptive that causes this problem?
