I am having problems with my lights in my renders. They are working for me from my shower angle, but not from my sink/door angle. In addition, I cannot figure out how to turn on the lighting fixture above my mirror in my renders. I am new to Revit, and wondering if anyone can help me with this.
Gelöst! Gehe zur Lösung
Gelöst von Jamhmer_Oc. Gehe zur Lösung
Hi @Anonymous
You must hide the wall that is shown in the view to render. Select in plan and hidden in camera view.
If you want to change the rendering tone, select the artifact and edit, change.
There is a lot of information on the net that will help you render better, good luck.
Jamhmer Oc
Thank you so much! Are there any sources that you recommend learning from?
Hi @Anonymous
Use this application, it will help you a lot.
https://apps.autodesk.com/RVT/es/Detail/Index?id=2629595860167800202&os=Win64&appLang=en
Here you can see a demo of what it does, it's good. From this you can follow the learning thread.
If the answer helped you, give kudos, if it solved your problem, accept as a solution. This helps other users to quickly find an answer.
Jamhmer Oc
