I am working on a big project which has 5 to 6 people working in their own local file each day.
The model is over 400 MB and we often get caught with each other even though we are working on completely separate parts of the building (we aren't touching the same elements or anything).
After each time myself or someone else tries to sync it comes up with the following error: 'Can't edit the element until "User" resaves the element to central and relinquishes it and you Reload Latest.'
This can happen with multiple users and as they sync they will get an error saying another user needs to resave and then we are caught in a loop. Sometimes we get users who have to lose work because it just keeps going back and forth. Does anyone know of why this would be happening if we aren't working on the same parts of the building?
Also when i place i hit 'Place Request' and look in the editing requests and click on the request that i sent, it highlights 2 specific concrete walls in our model which myself or the other user has not touched which makes no sense to me. Anyone have any ideas?
hello, you can refer to this LINK and all user's involve in the projects must be in the same build. thanks
check weather "editable" column in workset dialog box is showing "yes". If so, then sync your revit file and then change all worksets to not Editable.
