Hi, I am trying to schedule the length of the attached wire girder family.
I tried making a shared parameter for the category of model it is so that the schedule will have a length field, but it doesn't connect with the length parameter already on the family.
I tried editing the family and changing the length parameter to have a checkmark in the box for "Reporting Parameter" but it stops me and gives the error: "This operation will make formula of Parameter which contains '%1!s!' invalid."
Any ideas on how to schedule the lengths for each instance of this girder in my project?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Well, first off, you can't use a Reporting Parameter this way. You can however pull the Value from one Parameter into another like Parameter through a simple Formula such as Shared Parameter Name = Other Parameter Name.
But, why not just just make the existing Length Parameter a Shared Parameter?
