Problems of scale when i open a exported dwg at the illustrator
2 ANTWORTEN 2
Nachricht 1 von 3
563 Aufrufe, 2 Antworten
I exported my plan to dwg (version 2010) from the sheet page (i made a a4 format sheet) of revit, and i opend it at illustrator. But at the illustrator, the exterior line of the sheet(a4) became slightly smaller(about 1cm) than a4.
When i opened the same exported dwg file at the Autocad, i verified that there was no problem of length
at the layout tab (it was exactely the size of a4 in the layout tab).
So, the problem happens only when i open the exported dwg at the illustrator.
I attached the screen capture when i oped the dwg at the illustrator.
I tried to solve this problem for 3 hours, but i cannot find the way to solve.
* I already tried to check <export views on the sheet and links as external reference> but there was no difference.
And i also already tried to change the artwork scale option (original size or scale by 100%) on the tab when i open the exported dwg on the illustrator, but it was same.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Can you zip and share the DWG?
Nachricht 3 von 3
als Antwort auf: ToanDN
I attach here the DWG and AI with problem
