Problems importing FormIt .amx file into Revit 2018
8 ANTWORTEN 8
Nachricht 1 von 9
504 Aufrufe, 8 Antworten
I have been trying to import a FormIt file into Revit.  I've been using the FormIt add-ins and when it runs I get a message that the model is converting from 2016 to 2018 then it runs for a few minutes then I get an error message that it can't load.  I'm not sure of the problem.  Please advise
8 ANTWORTEN 8
Nachricht 2 von 9
Viveka_CD
als Antwort auf: Anonymous
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community!Smiley (fröhlich)
Can you post the error message you are getting?
Nachricht 3 von 9
als Antwort auf: Viveka_CD
FormIt to Revit Error Message.pngThis message skips popping up when I run through the process of importing the FormIt file into Revit.This message skips popping up when I run through the process of importing the FormIt file into Revit.
Nachricht 4 von 9
Viveka_CD
Hi @Anonymous
Thanks for posting the screenshots.
As the first step, can you confirm if you have the latest updates for Revit 2018?
Sign into your desktop app to check for updates and let me know if this resolves.
Nachricht 5 von 9
I'm having our IT department install any Revit updates.  What should I do after they are installed?
Nachricht 6 von 9
Viveka_CD
Hi @Anonymous
Once you have installed the updates, please clear your temp folder and relaunch Revit.
Check if the error still occurs and let me know.
If it persists, I'll be happy to do more testing if you can share the file and I can send you a private upload link.
I'm also waiting for further feedback from the FormIt team.
Looking forward to your reply update.
Nachricht 7 von 9
I have tried that.  Please send the me the private upload link.
Nachricht 8 von 9
Viveka_CD
Hi @Anonymous
I've just shared a private folder with you. Let me know if you have trouble accessing the folder.
Please upload your model, journal and extracted file using the shared utility.
Let me know if you have any questions!
Nachricht 9 von 9
Viveka_CD
Hi @Anonymous
Sharing feedback from the FormIt team:
They suggest completely uninstalling the plugin using Windows uninstaller and then redownloading and reinstalling from our download page https://formit.autodesk.com/page/download  (scroll down for the appropriate Revit version)
Let me know if the above recommendation works, else I will look out for your files.
Looking forward to hearing from you.
