HI,
I'm new to Revit. I'm trying to create a truss by following a tutorial. But the truss I'm getting looks nothing like those in the tutorial. I have attached a screenshot of the truss that I'm getting and a screenshot of the truss in the tutorial. Please can you tell me what I've done differently?
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
It appears that
1) your truss has less height than the tutorial
2) that you have not selected correct framing members
3) to connect to the top and bottom chords - You have to: unpin the members, stretch their lengths with the grips until they pass each other, then apply the coping tool. Now, select the member again, and the coping distance parameter will be available in the properties dialog box. See illustration.
