Problems after reinstall Revit 2020
3 ANTWORTEN 3
Nachricht 1 von 4
wjxu55
338 Aufrufe, 3 Antworten
After reinstalled Revit 2020, I can't find Revit 2020 iocn on desktop and Revit 2020 folder in c:\Program Files\Autodesk, only have "Revit Content 2020", "FormItConverterForRevit2020", also can't find Revit 2020 in Control Panel "uninstall or change program", only have Revit material library 2020 and Revit Content Library 2020. I try reinstall Revit many times, Still got same problems. Please help me fix problems. It is very urgent!
Thanks!
Willie Xu
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: wjxu55
did you install properly the program without errors? and you cannot find the revit 2020 folder? thanks
Nachricht 3 von 4
ennujozlagam
or go to control panel > file explorer options > view > select show hidden files, folders and drives and see if helps. thanks
Nachricht 4 von 4
wjxu55
als Antwort auf: ennujozlagam
Thank you!
I did clear uninstall, I found it is not completely installation, this time only installed 16 components, I installed more than 20 components before.
