problem with wrapping finishing layers of a wall
5 ANTWORTEN 5
Nachricht 1 von 6
linaa2016
483 Aufrufe, 5 Antworten
i have these 2 walls with a curtain wall in middle i creating parts of the 2 walls to control the finishing layers so i can change the height of them in exterior view but while doing that the wrapping finishing layers disappear is there any solution for this? there are attached screenshot i hope can help understand the problem.
5 ANTWORTEN 5
Nachricht 2 von 6
mariano_biagioli
als Antwort auf: linaa2016
lets see if I understand.
1. You created a "multi-layer" wall. (one element with structure and finishes) and the wrapping when you put a window is okey.
2. You created 3 walls separated and then joined them and here is the problem with the wrapping.
is ok my interpretation?
Nachricht 3 von 6
linaa2016
als Antwort auf: mariano_biagioli
yes that's it
Nachricht 4 von 6
mariano_biagioli
Ok. I have the same "problem".
As you, I think is a better idea modelling separate walls, but the problem is when you add a door or a window.
Revit will not resolve by itself cause is no the way that revit uses to make a multiple layer wall.
There are some things that you can do:
1. Get an average, of the total material used. If I had 10 cubic meters of this materials and I have 10 windows, ok I will use a 10% more of that material. (easy not precise)
2. Use a model in place, an extrusion with restrictions so if the window modify it fits. (You cuantity the material or volume)
and join the geometry so you dont computate the wall material twice.*
*I recomed this, you have to work a bit morre but it works on computation and visibility.
3. You add a parameter in the family that calculates the perimeter and volume of that finishes, (you don´t model, you only have the information)
If you want a screncast of the process let me know.
And if the answer helps you mark it as a possible solution Result of the option 2Result of the option 2:leicht_lächelndes_Gesicht:
Nachricht 5 von 6
linaa2016
if you could explain answer number 2 in more detail i would really appreciate it thank you.
Nachricht 6 von 6
mariano_biagioli
Here is the explanation.
(sorry for my english)
Please if it helps you don´t forget to mark it as a posible solution
:lächelndes_Gesicht_mit_lächelnden_Augen:
