Problem with Wall Sweep
I would like to know how to solve this problem.
I make the Wall Angle with Wall Sweep, due to the perimeter calculation.
However, at 90 degree junctions according to the posted image, it does not connect as it should. In this case it does not allow the Wall Sweep to be installed at the side of the wall.
Thank you in advance.
Salvar
Salvar
Salvar
Salvar
Is it one sweep or two seperate ones ?
can't you modify the sweep ?
If my answer solved your problem , Please Kudo  and Accept as solution.
Sahay_R
Use the same profile to create a Railing. The Profile will be the Top Rail. Remove the Balusters etc, change the height of the top rail to 0.
The reason for this is that Railings are very forgiving and they can be created in very complicated shapes as well.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Copy and paste that particular corner with walls and wall sweeps to a new file and upload.
chrisplyler
I suspect that you have placed two separate sweep instances.
If you escaped out of the sweep placing mode, and started again, then that is the result. Delete one of them, and replace it by selecting the other and then clicking the "Add segment" tool on the ribbon. In this way you can add back the necessary walls and it will all be one sweep element. Then all the corners will miter correctly.
Thank you all for the answers and sorry for the delay in answering them.
However, Wall Sweep has been created in a unique way, but when it reaches the gap it does not allow to create because it is one side of the wall, so I have to create a corner, then it does not join properly
Thank you
