problem with visibility graphics
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
pics.munmun
473 Aufrufe, 2 Antworten
why visibility graphics is applied to only two columns and not on all columns of the floor?
please help me settle this.
Beschriftungen (4)
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: pics.munmun
activate your bulb icon and unhide your plan region and adjust to include the other columns? thanks
Nachricht 3 von 3
RDAOU
@pics.munmun
It is applied to all columns...I can see in you image
  1. wherever the column is cut it is overridden with Light green
  2. wherever it is not cut it is overridden with dark green
What to do:
  1. Either check in section view and adjust the Top Constraint of the columns (connect or attach them to Level Above)
  2. OR check view range and adjust cut plane level/offset
  3. OR add a plan Region for that area and only adjust cut plane for that region
