i have hidden lines appear in my view port only in 3D Views that make me confused
please check my video to see problem
thank you
my RVT file attached to see this File
Solved by barthbradley. Go to Solution.
It's not you. It's Revit and a known/documented issue. Has to do with the thickness of the wall layer. If it's too thin, it won't hide elements behind it properly.
thank you for your comment
but i need to make this layer 0.02 thickness, any way to make revit work fine with this thickness ?
