Problem with upgrading file from revit 2017 to revit 2018
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
giapanotis
386 Aufrufe, 3 Antworten
Hello!
I have a model from revit 2017 and i want t put it in revit 2018.The versions that i have are for educational use.The laptop that i have is i3 also the desktop and the graphic card are also weak.When i want to upgrade i check the audit ,it is showing that the files are being upgraded but simply stops and doesnt open it.The files contain a lot of families that i have downloaded,the size is 45 mb.I have done the same procces with  a lighter model that was 35 mb and it worked!
Do you have any idea how to solve it?(i deleted some families t make it lighter but the result is the same).
Thanks a lot for your time.
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: giapanotis
What's your build? There is a 2018.3.3 available. Try applying the latest and greatest.
Nachricht 3 von 4
giapanotis
als Antwort auf: barthbradley
Thanks for the replying ,
I go to my account and i try to find the update that you mentioned and i can't find it!
I have downloaded the version of this revit this week ,so maybe, its already updated?
I am trying to open the desktop app and shows an empty window like this.
Nachricht 4 von 4
giapanotis
I finally did it ,i went to my desktop(i have already installed same version in 2 divices )and the desktop app was working fine!I installed the update and everything was cool!
Thanks!
