Problem with transparency in materials in Revit versions after 2020
3 ANTWORTEN 3
Nachricht 1 von 4
marinaKXNYB
460 Aufrufe, 3 Antworten
Hi!
I'm trying to configurate materials that look a little transparente, like a voil fabric, but when i open the same family in other versions (Revit 21,22 and 23), the transparency doesn't work unless i leave it very low, like 4%. More than this is opaque.
I've also tried to use a pattern with a cutout, which works perfectly on Revit 2020, but is horrible when open in 2021 and after.
Does anyone know how i can make it look the same in all versions? Is there any settings i can use?
Beschriftungen (5)
3 ANTWORTEN 3
Nachricht 2 von 4
vitorbortoncello
als Antwort auf: marinaKXNYB
Make sure to use the same render appearence path:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 4
Nachricht 4 von 4
