I created a topography from imported file, as you can see in the attached.
The contour of the topography is straight lines, and not as the import file (I marked in red the line that I would like to create).
Does anyone know what to do?
Thanks!
Amit
There is no attachment visible.
The CAD line work is flat. That is, the line work representing the contour lines have no elevations. You need a 3D mapping.
I might have another way for you, but I'll need to check out your CAD file to see what information it has. Can you post it?
