Hi all,
I modeled a single railing to adapt to my stairs. I just have the problem that the three posts that should be on a single step, are indeed aligned with the previous one. This results in a prolongement under the step. What could be the cause? See screenshot attached.
Thank you!
D.
Gelöst! Gehe zur Lösung
Gelöst von davidefranco92. Gehe zur Lösung
Solved.
I designed the step´s profile in the III quadrant. Moving it into the I, solved the problem (despite the fact that Revit stadard family message is telling you to design there).
Thank you @barthbradley for the message!
