Hello. I've been trying to add dimension info as a text in a door family (in plan view). After some research I've found out that I have to create a generic annotation family with a label and add it to the door family as a symbol. I added the parameters and stuff and it worked. However, when I change the scale from 1/50 to 1/200, since revit tries to keep the text size (in print) the same, it became too big relative to the door size. I've done some google search and everyone basically says its supposed to work that way. I want to know if there is any solution to this problem (workaround is fine if it doesn't take too much time). Thanks.
Revit version : 2018
Windows 10
Graphics card : Tried on different computers, same result so not important probably
1/50 scale
1/200 scale
Gelöst! Gehe zur Lösung
Gelöst von loboarch. Gehe zur Lösung
You are correct this is the way Revit handles annotation elements. The only way around it would be to make a tag designed for specific scales and adjust the text size in the tag family itself. So you will need to figure out how big the element (door) is at a specific scale and then choose a size of text to use at that scale related to the element (door).
Seems to me though, the text that will fit in relation to the door at 1/200 might be to small to be read easily. Maybe my eyes are old?
I was trying to find a solution which doesn't include me adding a tag for each window and door. I couldn't add a tag to the door inside the door family. Maybe I should find a way to add tags to all doors and windows at the same time. Thanks for your reply ![]()
edit: I know in 1/200 that text is too small. If there was a way to hide that text in 1/200 scale only that would also work for me.
The "Tag All" tool will tag all elements in a category at one time.
