I have created objects in Rhino and imported them to Revit (basic geometry is the same in both). I can snap to the first one but not to the second. What could be the problem?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Export as separate Elements...ie: each as a 3dm >>> then import both into the same family/in-place
Otherwise use a different format than .3dm
Alternatively use the Rhino plugin which provide interop Revit and Rhino https://www.rhino3d.com/features/rhino-inside-revit/
RhinoinsideRevit worked. The reason might have related to the orientation/ortho of the object.
