Problem with Revit - wheel bottom right and cannot save the file
2 REPLIES 2
petruzzi
255 Views, 2 Replies
Good morning,
I have another issue, this sign bottom right is preventing me to save the file and I'm not sure why is happening. Thank you
2 REPLIES 2
TripleM-Dev.net
in reply to: petruzzi
Hi @petruzzi,
In this Link Autodesk list as cause a corrupt windows profile. While a new profile could solve it, it seems to me a bit extreme action.
First, I think to be able to save, close any view with a color fill set, or remove the color fill scheme from the views so no fill is applied and save.
Does this also happen on another pc with the same model, if not try the following:
If it's a workshared file, create a new local, but first:
 - Close all Revit windows.
 - make sure to delete the old one first AND it's backup folder.
 - Clear the windows temp (type in %temp% in the windows explorer and it takes you directly to the temp folder)
 - To be sure restart the Pc
If it also happens on another PC, try auditing the Central file itself, and maybe create a new Central file from it.
petruzzi
THank you, what do you mean exactly? First, I think to be able to save, close any view with a color fill set, or remove the color fill scheme from the views so no fill is applied and save.
Forma Design Contest
