Problem with revit links
2 ANTWORTEN 2
Nachricht 1 von 3
nicol_mukaj
137 Aufrufe, 2 Antworten
I have a problem where the Revit links don't appear in a specific floor plan but when I open other floor plan everything shows up. I checked the VG everything is in order. I checked the view range also no problem. Tried to see if anything was hidden but no hidden geometry, also closed and reopened the file still in this specific floor plan nothing shows up.
2 ANTWORTEN 2
Nachricht 2 von 3
ramneetkaur86
als Antwort auf: nicol_mukaj
The Jpeg is not clearly showing the issues in view where revit links are not visible. Please share a better Screenshot of two views 1. where they are visible and 2. where the revit links are not visible.
I am assuming the problem also might be that  the linked model is not positioned correctly. If the link has been moved, it's possible it’s outside the view range of the floor plan in question
Nachricht 3 von 3
nicol_mukaj
als Antwort auf: ramneetkaur86
Thank you I fixed it. The reference level had moved that's why nothing appeared.
