problem with removing a roof
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
linaa2016
916 Aufrufe, 9 Antworten
hello hope everyone is fine i have a question regarding a roof i have made in revit once i made it i just can't delete it does anyone know where is the problem? i added a screenshot to clarify what i mean and thank you
9 ANTWORTEN 9
Nachricht 2 von 10
ennujozlagam
als Antwort auf: linaa2016
it could be pinned or try to reboot your machine sometimes it happen you cannot do anything? and see if helps. thanks
Nachricht 3 von 10
linaa2016
no i checked its not pinned and rebooting doesn't do anything it's just like that i can't edit or delete these elements
Nachricht 4 von 10
ennujozlagam
can share to file or send to my email add to check? thanks
Nachricht 5 von 10
linaa2016
ok could you write your email please?
Nachricht 6 von 10
ennujozlagam
or try to edit your roof > edit type > structure > it could be in your edit assembly? thanks
Nachricht 7 von 10
ennujozlagam
check your PM thanks
Nachricht 8 von 10
ennujozlagam
it's a curtain wall categories > go to east elevation > activate your bulb icon > select and delete. thanks
Nachricht 9 von 10
linaa2016
ok thanks so much
Nachricht 10 von 10
laureta_calebkarl
how can I delete roof without affecting the shape of the walls attached to it?
