Hello everyone,
I am facing a problem will try to explain:
I have Family A (host family), contains some nested families and family types, lets say Family B (nested shared family)
Family B has some type parameters.
when i change some parameters for Family B within Family A, and then reload Family A (host) to the project, the project doesn't update the new parameters of Family B (nested)
attached this example in revit 2024 files
The example is to open family A and change some parameters of Family B (which is nested inside), then load Family A into a project
The problem: the updated parameters of the Family B is not updated
sometimes the a dialog appears if i wanna overwrite the parameters or not, sometimes the dialog doesn't appear at all.. the revit has a random behavior in this issue..
please advice and help, noting that, this is just a sample but in my real project Family A is a very huge family contains many nested families so any manual solution will be nearly impossible
One more final note: i tried to make the parameters shared but it wont solve the problem also..
Thanks in advance
