I am experiencing a display issue in realisitic elevations with REVIT 2022. It doesn't happen all the time, just randomly. As suggested by Autodesk, I do open all my projects through the Revit desktop app and on occasion my elevations will become a dark grey color (not what they are programmed to be) and there is often a secondary outline of portions of the elevation(s).
I've set all of the views to PHASE: NONE and I still have this issue. What am I supposed to do to remedy this? Is Autodesk working on a fix?
I have a 2019 BOXX APEX S3.04 with 32 GB of RAM, but there is often a warning stating I need more memory???
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If the issue is not solved, you may also stick to the same post you do not need to re-post it again...I am pretty sure that ToanDN would have continued to give you suggestions on how to fix it
Realistic View = Sun Settings (I will post you a detailed reply on your other post Link below)
