Problem with Railing End post.
16 ANTWORTEN 16
GELÖST
Nachricht 1 von 17
4765 Aufrufe, 16 Antworten
I am having an issue with railing post here.
I want the end post of type-2 railing like it is shown in type-1.
Both the end posts have been modeled separately with one side glass holder clamps.
I could not achieve it even after spending long time with the settings.
Please find the attached reference files. (Revit file created in 2018 version)
And help me out please.
Thanks.
Tags (3)
16 ANTWORTEN 16
Nachricht 2 von 17
als Antwort auf: Anonymous
So you want a corner post at each segment end?
Nachricht 3 von 17
Can you share the file?
On another thought, can you build the clamps into the panel family so that you only need a single family for baluster and posts?
Nachricht 4 von 17
als Antwort auf: ToanDN
@Anonymous: my point was that you have "Never" set under "Corner Post at". Set it to "Each Segment End".
The sample rail project located here may be of help to you:
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2016/ENU/Revit-GetStarted/files/GUID-899499DB-C96A-4C66-8500-0CC4E3FD62B1-htm.html
Nachricht 5 von 17
Sorry i forgot to include the revit file.
Here it is now for the reference.
Note : It is in 2018 version.
Tags (3)
Nachricht 6 von 17
Duplicate Deleted
Nachricht 7 von 17
I'm not at a 2018 station right now, but did you try what I suggested? That should do the trick.
Nachricht 8 von 17
Please have a look at the revit file that i have shared.
Your answers helps me to finish the work for now.(attaching clamps to the panel)
Still is there any way to fix this by adjusting settings?
Thank you @ToanDN
Nachricht 9 von 17
als Antwort auf: barthbradley
oh, and spread main pattern to fit as well
Nachricht 10 von 17
@barthbradley
I tried that even before taking the screenshot.After seeing your post i tried changing that. but no result.
And the link you have attached is not working !
but i finish the work as ToanDN mentioned (Attaching clamps to the panel)
 Thank you.
Nachricht 11 von 17
Spread to fit didn't work (on Main Pattern) either?! Weird. Also, weird about that link. I copy and pasted it at the same time I posted the reply. Someone else reading this thread here, must have grabbed the last one off the site. They ran out of stock I guess. HA!
Nachricht 12 von 17
Smiley (überglücklich)
Spread to fit pattern gives me the expected solution in the corner post.
But it moves the panel location.
Still i am attaching the solution here that i gave me relief for now.
Nachricht 13 von 17
Nachricht 14 von 17
Wow thats really some good information to understand more about railings!
Thank you.
Nachricht 15 von 17
@Anonymous
See attached file.  I had to set the start and end post spacing to 0 and extend the top rail by editing its path.  Still, I would go with keeping the clamps in the panel family (1) instead of the posts and balusters (2).  (1) you only need one baluster family for all conditions. (2) you need a number of post families to cover corner turning left, corner turning right, and different angles if you have them.
Nachricht 16 von 17
 @ToanDN. Thats awesome.
Thanks for spending your time on the file.
You are correct.  I finished the work by attaching clamps to the panel. I found it is the easiest and smart way for my case.
Thumps up.
Nachricht 17 von 17
Viveka_CD
Thank you @ToanDN and @barthbradley
Hi @Anonymous
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
