Problem with material image scaling
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
flleroux
3065 Aufrufe, 4 Antworten
Hi!
When I add an image in the appearance tab and try to change the value to 610x610 for example it changes automatically one value to 610.05. This is frustrating because the image won't correspond to the pattern in the graphic tab. Can you guys help, thanks.
Tags (3)
Beschriftungen (2)
4 ANTWORTEN 4
Nachricht 2 von 5
Lance.Coffey
als Antwort auf: flleroux
Thank you for the question @flleroux, and welcome to the Autodesk forums!
From the provided screenshot, I’m seeing that the aspect ratio is currently locked for the Scale parameters. This means that when you adjust the height, or the width, then the other value will be automatically adjusted to maintain the aspect ratio.
If you want to adjust these values independently, then click the small chain icon (to the right) so that it is not highlighted in blue. For more info on these settings, see the help topic Texture Editor.
Lance Coffey
Technical Support Specialist
Nachricht 3 von 5
flleroux
als Antwort auf: Lance.Coffey
That is correct. But even if I remove the chain and try to set it to the correct value it automatically put it back to the number with decimals and not rounded up.
Nachricht 4 von 5
Lance.Coffey
If you are seeing this when making a small change, like 605.05 mm -> 605.00 mm, try making a larger change first (for example 605.05 mm -> 305.00 mm) and then change to the desired value (605.00 mm).
Another thing to try would be increasing the precision in the Project Units so that 3 or more decimal places are displayed.
Lance Coffey
Nachricht 5 von 5
flleroux
I've finally been able to change it to a round number by copying the number and then by constraining it.
https://www.screencast.com/t/uofvL6V3i
