Hello everyone,
I'm having a problem in the lighting plant, I'm currently using a Floor Plan with the Underlay - Look Down" active, I use the Lighting Fixtures with annotation symbols because of the legend, but I've come to realize that the symbols are not overlapping the items below it.
When I use only the symbols they overlap, however when I use the "Lighting Fixtures + Symbols" does not overlap.
Is there any possibility that symbols within the Family behave as if they are not?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Thanks "barthbradley",
I changed the cut plane and it worked in relation to the overlap of the computer, however I would like the symbol to overlap all the elements, I verified that it does not overlap the furniture for example, unless I changed the cut plane for it cut the furniture in specific. This is somewhat palliative and the result is not always satisfactory.
Look
