10:58 AM
I have problems importing Sketchup terrain to Revit. I've watch a lot of tutorials but nobody addresses the spacing of the imported mesh. I export as dwg, in Revit Import CAD (I have tested all different settings) but no luck. When I create contour lines the surface still has this problem. Is there a way to make the spacing of the mesh more dense? Should this be done in sketchup, export settings?
thanks
