Dear alls!
I'm a newcomer. I have some proplem when working with Revit (2017 ver)
The First, i create a Family door (att file DOOR WFIXFR). In this file, i had success with all parameter when changed it. And then, i create a Detail item family such as a lintel for door. i loaded it into and its had already right when i change ( H FIX FR parameter).
The problem had appear when a create another family door (att file DOOR BR), and the last, i loaded Detail item Lintel like the fisrt family door. But... when i change the Height, it failed and had a warning that can't creat this lintel item....
I had recheck all bit not to know where is the reason for this problem...
Please help me to solve this problem...
My English is not good and may have some wrong, but hope you can understand my problem.
Big thanks to all of your team for Revit Soft.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You constrained the lintel's shape handle to the reference plane, that's why it breaks when you change the Door Height. You need to constrain the bottom Reference of the lintel instead. I fixed it and it flex okay now (Height changed to 2400 from 2200).
Chuc may man!
tks so much :), vietnamese? so proud of u...bestwish!
@ToanDN wrote:You constrained the lintel's shape handle to the reference plane, that's why it breaks when you change the Door Height. You need to constrain the bottom Reference of the lintel instead. I fixed it and it flex okay now (Height changed to 2400 from 2200).
Chuc may man!
File bạn fix đã hoạt động đúng. Nhưng Toàn có thể giải thích rõ hơn giúp mình được không?
Mình làm thứ tự các bước là vẽ xong family cửa, sau đó load family lanhto vào ( tạo 1 section và làm việc trên đó, load lanhto chọn ref là center/left right), mình align cạnh dưới của lanhto vào Ref plan và khóa, 2 cạnh biên thì kéo hoặc align với 2 biên tường và khóa lại. Vấn đề là file trước đó mình cũng làm vậy, nhưng hoạt động ok,còn file này lại bị lỗi đó...
Mình mới làm revit nên còn chưa rõ nhiều vấn đề, mong Toàn chỉ giúp nhiều nhe.
Chúc bạn sức khỏe và luôn thành công trong cuộc sống.
ôi trời, chi tiết nhỏ nhưng quá quan trọng với mình.Vậy là chứng tỏ file trước đó làm đúng là vì... may mắn chọn đúng ref của lintel...thật ra mình luôn tab chọn và để ý trên tooltip, nhưng không để ý đến ref của lintel...cũng do tự mày mò từ mấy clip trên mạng nên chuyện căn bản thế này mình hoàn toàn không biết...Cảm ơn bạn rất nhiều!!!Rất vui vì biết bạn :)! T ở ĐÀ NẴNG ah? mình ở SG, có dịp mời Toàn CF nhe, mình sn 84, không biết xưng hô với T sao? nếu bạn lớn hơn thì mình sorry nhiều vì đã gọi là bạn nhe.
Chú Toàn giúp giùm cháu cái này với.
Cháu có 1 family cửa, sau đó cháu vẽ khung bảo vệ. Vì cháu muốn tùy biến nó về sau khi thay đổi kích thước thì số thanh ngang cũng tăng/ giảm theo khi chiều cao thay đổi. Cháu tạo 1 extrusion trên mặt Interiod, định độ dày và gán Ref là steelfr, sau đó cháu array cho đối tượng này, gán 1 parameter có Group là Constraints và Type là Integer, thêm Formula cho tùy biến số thanh này tăng/ giảm theo biến "H Fix" --> khi thay đổi H fix thì cháu thu được số thanh khá ưng ý và đúng với ý đồ cháu muốn làm, nhưng khi cháu thay đổi thử Width thì...các thanh này không thay đổi đúng dù ban đầu các biên rộng đã được khóa theo 2 biên bên, cháu để ý thấy là khi đối tượng này chưa là group thì thay đổi Width ok, nhưng lúc array và muốn có tham biến số lượng thì các đối tượng đó sẽ là group....Cháu tiếp tục đặt Formula bề rộng của biến này thay đổi theo Width nhưng vẫn không được.
Cháu làm thử nhiều cách suy đoán trong vốn kiến thức hạn hẹp nhưng không thể giải quyết được vấn đề này, rất mong được chú chỉ bảo, vì trong Group parameter under còn rất rất nhiều mục mà cháu chưa hiểu, cháu tìm các tài liệu trên mạng cũng không thấy topic nào giải thích công dụng của từng mục trong này.Cái Constraints này cháu biết là vì mày mò ở 1 file family, thấy họ dùng để tùy biến số lượng hay quá nên cháu áp dụng vô trong family của cháu, nhưng bề rộng thì không thể khống chế được, cả file gốc của họ cũng thế...Bí quá nên đành phiền chú vậy ![]()
Rất mong nhận được phản hồi của chú và cháu cảm ơn chú rất nhiều.
WOW... đã hoạt động được theo ý e rồi. Rất cảm kích về file a đã giúp, để e nghiên cứu thêm file này, rất mong được học hỏi nhiều từ a. bestwish ;)!
